F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #31
Old 06-11-2008, 02:13 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
im not sure whether the key is made out of a hardened steel, but im pretty sure you could knock the old key out, get new key stock and get to work. the real hang up would be verifying its standard key stock or if its "special"
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #32
Old 06-11-2008, 03:03 PM
Vehicle: 2003 ford f150
well the motor is gonna get honed and dipped soon so ill finally have a break
[IMG][/IMG]
  #33
Old 06-12-2008, 03:08 PM
hey, do any of you guys have any aftermarket bigger fuel injectors for sale..if so let me know ASAP...thanks
[IMG][/IMG]
  #34
Old 06-12-2008, 05:14 PM
i was gonna say check joey, but i think he's keepin his 42's now that he dropped some boost.
JMC or Neal?
  #35
Old 06-12-2008, 06:27 PM
Vehicle: 2003 Fast Screw
Here's a set...http://www.nloc.net/classifieds/show...uct/5822/cat/7
How big do you want to go?
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #36
Old 06-13-2008, 02:03 PM
id say no bigger that 42lb's
[IMG][/IMG]
  #37
Old 06-13-2008, 02:11 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
while you have your intake off you may want to modify it like neal did to his for a bit more top end power...
  #38
Old 06-13-2008, 02:41 PM
yep i think we are doing that tommorrow while my blocks at the other shopeven though the cams i got are pretty huge.they will provide plenty of top end power
[IMG][/IMG]
  #39
Old 06-15-2008, 12:16 AM
hey my new cams which are comp cams 102600, have like a key slot on the end of the cams but my factory cam gears dont have any keyway slots...do i need aftermarket cam gears or do the factory ones come off and work.....also my friend with a 95 5.0 mustang wants to know if a fox body throttle body will work on his car, its an aftermarket bbk..please help ASAP...thanks
[IMG][/IMG]
  #40
Old 06-15-2008, 01:12 AM
your stock cams are pressed on gears. there was some bolt on cam gears for mustangs around 99. you need those, and they need to be modified to allow you to index the cams correctly
  #41
Old 06-15-2008, 01:18 AM
well i found some adjustable cam gears from rpmoutlet and they are the comp cams gears..cant i just buy those and the gear install kit, and wont that take care of it?
[IMG][/IMG]
  #42
Old 06-15-2008, 02:05 AM
yes, those are more expensive than the method i mentioned is all.
  #43
Old 06-15-2008, 03:00 PM
and im assuming that i need to get the cam gear install kit as well...right?
[IMG][/IMG]
  #44
Old 06-15-2008, 03:08 PM
whats a cam install kit?
  #45
Old 06-15-2008, 03:26 PM
Vehicle: 1998 FORD F 150
Quote:
I don't think the kit is worth the money, as it does not include the solid lifter, etc. I assume you are speaking of the Comp Cams kit. You can dig up what you need from your buds, etc, but you'll need the lifter. built54, help here?
Here's a goody:http://www.modulardepot.com/articlesp.php?aid=32
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
