F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
Old 06-07-2008, 02:26 PM
Vehicle: 1998 FORD F 150
Quote:
Originally Posted by boss1984 View Post
alright, alright you guys talked me into it its almost time to start...about 5 hours to go
Hmmmm....are you excited?? Ok, here's a nanner!!!
Old 06-07-2008, 02:42 PM
Vehicle: 2003 ford f150
i dont think excited is a good enough word.. im also a little nervous..hopefully everything fits well and there are no problems
[IMG][/IMG]
Old 06-10-2008, 03:56 AM
alright guys.. as of now the motor is pulled and on an engine stand..the pull wasnt to bad.. i was surpised that it came out with the longtubes on, the condensor in and all pulleys..now while we were tearin the motor apart..theres this part(sorry no pics yet) that was just inside the front timing cover on the bottom looks like a gear..but its not its where the keyway is for the crank..whats the name of it..hopefully i described it good enough for you..the keyway is broke and i need to replace the thin gear like part..also that part looks like it has teeth that are bent at a perfect angle...AND ALSO the actual key was broke..
[IMG][/IMG]
Old 06-10-2008, 04:19 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
crank position trigger wheel?
FYI, the one you mentioned is the thinner one, i believe it is also for the later years of the trigger wheel. yes this matters.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 06-10-2008, 02:11 PM
yeah its right infront of the bottom gears for the timing chain..that part slides off then the timing gears on bottom
[IMG][/IMG]
Old 06-10-2008, 02:22 PM
yeah its the trigger wheel, crank trigger wheel. if its the thin one with curved teeth on top its the thinner version, which if memory serves me correct, is the later version of the trigger wheel.
Old 06-10-2008, 02:40 PM
yep thats it..do you happen to know where i can get one..because for some reason the keyway opened up and is about 1/4 in bigger than what it should be..thanks
[IMG][/IMG]
Old 06-10-2008, 02:46 PM
i think its ford only... or at least i couldnt get one any other way. its like $50 range
Old 06-10-2008, 02:56 PM
ok thanks.. do you have any idea on why the keyway expanded larger than the key..about double the size of the key
[IMG][/IMG]
Old 06-10-2008, 03:21 PM
no, but im sure someone with a few beers can provide a theory.
my only question is there a fracture in it anywhere? somehow it had to get play in it in the first place to continue thrashing itself.
Old 06-10-2008, 04:50 PM
Vehicle: 2004 Ford F150
Keep up the good work.. I can't wait to see it when its done!
2004 5.4l Fx4, Edge Evolution, Volant CAI,
Straight Pipe Exhaust, 3:73 Gears,
10" Pioneer Sub, Clarion Touch Screen,
Blue L.E.D Signals (Got pulled over, so back to amber). Chrome handles and Mirrors,
2.5" A.S. + 3" block 305/65R18 BFG A/T KO's
Custom tunes from Bill!
Old 06-10-2008, 05:43 PM
i dont see a fracture anywhere..3 of us were shocked to see it..we had to pry that damn trigger wheel off because of it..im headin to the shop now to finish tearin it apart. got about an hour or so..then the block is gettin honed.then back to rebuilding..oh yea..if any of you guys have a MySpace..i do have about 20 pics up there my email is marinonrm@yahoo.com..check em out there for now
to jonamond i cant wait either..should be about a week or so depending on how long the block takes
[IMG][/IMG]
Old 06-10-2008, 07:20 PM
Vehicle: 1990 ford f150
Send a message via AIM to krazyballer
Wow sounds good so far keep up the good work
1990 f150
toyo open country a/t
super 40's
"Semper Paratus"
Old 06-10-2008, 09:50 PM
^^well im done for the day.my block is down to nothing and is getting hot tanked within the next couple days..so far nothing to serious is going on as in problems..
[IMG][/IMG]
Old 06-11-2008, 01:59 AM
oh yea.. i forgot i had one more problem..the key on the crank has a piece broke off of it..can the key be bought seperate from Ford or do i need to buy a whole new crank..thanks
[IMG][/IMG]
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
