F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #211
Old 10-05-2008, 01:45 PM
Vehicle: 2003 ford f150
Quote:
Originally Posted by Klitch View Post
im not good at math, but im sure you'll be irritated about the time and money for double checking your cams.
im sure i will be shouldnt i be at around 350whp N/A
[IMG][/IMG]
  #212
Old 10-05-2008, 01:48 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
sprayed? yeah
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #213
Old 10-05-2008, 01:50 PM
so i should have 350whp on spray..or N/A
[IMG][/IMG]
  #214
Old 10-05-2008, 05:23 PM
Vehicle: 1998 Ford F150
i would think 350 to the ground without spray is about right for what you have.
  #215
Old 10-05-2008, 05:46 PM
Quote:
without spray i only put down 270hp/301tq
[IMG][/IMG]
  #216
Old 10-05-2008, 05:49 PM
what a/f are you at and how much timing
  #217
Old 10-05-2008, 05:55 PM
i believe 21* timing tried to go more/less..truck didnt like it..a/f is right about 11.5 or so
  #218
Old 10-05-2008, 05:58 PM
dang... you should be making more. did you data log those dyno runs?
  #219
Old 10-05-2008, 06:00 PM
i know i should..my tuner thinks it may be cam timing or the chains weren't lined up properly.. do u think that could cause that much of a power loss..im not sure about the datalogging since the tuner took care of it
  #220
Old 10-05-2008, 06:09 PM
built, what do u think could be the problem(s) for that much of a power loss
  #221
Old 10-05-2008, 06:11 PM
I Think if the timing chains were not where they should be, you would have a noticeable problem at idle, or normal driving...
  #222
Old 10-05-2008, 06:13 PM
do you mean like the truck would die sometimes and what problem would it be with normal driving as u say..if its not the cams what else could it be
[IMG][/IMG]
  #223
Old 10-05-2008, 06:30 PM
I would think it would run really rough. have you done a compression test?
  #224
Old 10-05-2008, 06:32 PM
yes just 2 days ago i put in new NGK TR6 and i had 140-150 psi in all cylinders
  #225
Old 10-05-2008, 06:35 PM
well with my pi head swap, comp cams, long tubes, injectors, and 90mm maf, I put down 265/325. that was with my heavy tires and wheels, and its 4wd... so that was roughly 325 flywheel hp.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
