2002 4.6L Cylinder Heads - F150online Forums
Old 05-09-2008, 12:09 PM
I have to replace a head, IIRC that the heads were re-designed because of the plug spitting issue on some of the 03 engines. Will these redesigned heads fit on an 02 4.6L? If so how do you identify the newer design?
Thanks for the help.
Old 05-09-2008, 02:15 PM
Not sure what you mean by IIRC. I've heard the term, but it's not a head specific term AFAIK ? Casting #'s - But I have no idea what they are. Only other way is counting the SP chamber threads. I believe these heads are on the 03 - 07 4.6L's. Also the 03 5.4L.
Old 05-09-2008, 04:03 PM
Sorry:o IIRC was short for If I Recall Correctly, I just remember seeing on here before that some of the 2003 heads had changed and had more threads in the plug holes than the ones on my 2002.
Old 05-09-2008, 04:08 PM
Are you replacing the head due to a blown plug hole or is it cracked? It would be far cheaper to have full length hard anodized plug threads locked into the heads than replacing one. I had both heads done for $200.
jbrew, IIRC = If I Recall Correctly
Old 05-09-2008, 04:12 PM
Quote:
Oh that's right , I haven't seen that in awhile. I'm pretty sure all 03's were changed but can't verify. It might have been a mid year mod. They tend to do that sometimes, to use up what they have on hand first.
Related Topics
Thread
Forum
Replies
Last Post
Kevin Gaston
V8 Engines
9
06-29-2016 09:53 AM
02xltscab
Introduction Forum
5
11-06-2015 09:23 PM
BryanPaDo
V8 Engines
3
11-05-2015 08:18 PM
5.4swap
10-01-2015 07:59 PM
Dean20653
V8 Engines
5
09-30-2015 04:27 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
