Gears... Stock to a 4.88 i think its called
I have stock gears now, Im putting on a lift and getting anywhere from 35s to 37s should i change my gears? im a noob when it comes to anything with a truck so im not sure the advantages/ disadvantages plus i hate it when i try to light them up only one wheel spins is this due to the gears also? any help would be greatly apreciated
Originally Posted by Typow07
haha woops being a noob i thought gears were in the tranny so 4.46s are ok? how would i go about putting something like that in? and what stops both of my tires from spinning when i try to peel out or something i was told something bout not a solid axel or something?
Thanks a bunch, everyday i get on here i learn about a million and a half more things that i can use for my truck. I have the 4.6 and i will most definitly have a shop instal my new gears do the gears help performance or whats with them... maybe a little faster with the bigger tires i would assume
gears determine how hard your engine has to work to get your tires moving. It's just like a bike, go hop on one and try to start pedaling in 10th gear, then try it in 1st. the gear at the pedal stays the same (engine) it's the gear at the wheel thats different. if you have to spin the pedal say 10 times to make the wheel spin once it's easier than having to spin the pedal 1 time to get one wheel rev. PS if you regear you will run higher RPM's (not much maybe 300) at most speeds. but it's healthier for your engine, and your legs if you have the right gears to get you moving. and yes you will have better acceleration because it will take less effort to move the beast that is your truck
