i went with Comp Cams #102600, comp cams said they were the biggest cam we could use without performance internals. There is another one simular i think #102400, but i would go with 102600 but keep in mind they are ($550) and you need Comp Cams Behive valve springs #249-26113-16($220), ARP head studs are recommended ($220) Head gaskets ($75) And you might as well get timing chains with tensioners ($120) And it wont be worth it unless you get the heads ported, which 3 angle bench ported by someone whos familiar with ford modular will run you $6-800. Otherwise your waisting your time as ive read and heard. And im in the process right now. Just need to get the heads taken care of and put it back together. Lets hope we arent waisting our time and money for the gains achieved! But good luck and hope to see someone else do this too!
99' F 150 4.6 swapped 2002 5.4 and trans.
Pacesetter lth's to Magnaflow hi-flow cats, UD pulleys w/ gatorbelt, e-fans,ac bypass pulley, 9mm wires & MSD coilpacks, K&N air intake, EDGE EVO, Stage 2 Comp Cams and ported heads, Comp Cams behive valve springs, 3inch body lift w/ 35" BFG Mud Terrains on black Cregger steal rims and Eaton Posi-Unit 3.55 gears.
