2004 ford F150 won't start
Old 03-10-2008, 06:32 PM
dlptnp's Avatar
Only drive this truck mainly on weekends. Hasn't been driven since Saturday, but when I tried to start it, it said "check gauges". The gauges that it said to check have nothing to do with it not starting, as you can only do it with the motor running.
Old 03-10-2008, 08:36 PM
torkum's Avatar
Battery is too low, needs charging
Old 03-10-2008, 10:04 PM
dlptnp's Avatar
Battery is fine it won't do anything
Old 03-10-2008, 10:31 PM
bxstang2000's Avatar
So the car wont even crank over?
Old 10-06-2013, 06:25 PM
LJByron's Avatar
So does anyone have a clue to what the problem is. I drove mine Tuesday then again Friday night. Saturday morning will not start. States check gauges, oil is fine, fuses are good, replaced the oil sensor. Tried to remove the starter to get tested but could not remove it. Truck only gets driven 1-2 times a week and weekends. Any help is appreciated.
Old 10-06-2013, 06:36 PM
jethat's Avatar
So your saying its a no crank situation? Check the batterys charge then connections. Ford starters rarely fail so thats the last thing you wanta mess with. The main starter wire to the starter corrodes in winter climate so check it for internal corrosion.
Old 10-06-2013, 07:43 PM
LJByron's Avatar
That's correct a no crank situation. Battery connections are good we even tried to jump and that was a no go. We went through the test, at that time all the gauges moved. When I go to start all the gauges move with the exception of the oil. I did get a dtc code d900 and d950.
Old 10-06-2013, 07:45 PM
LJByron's Avatar
When he was messing with the starter, all the wires are good nothing corroded. We live in Florida so no really harsh winters. I am just at a loss right now with this.
Old 10-06-2013, 07:49 PM
FPDM... have you checked it? It's above the spare tire. See if it is corroded and cracked
Old 10-06-2013, 07:59 PM
LJByron's Avatar
He looked at it through the side and it didn't look corroded.
Old 10-06-2013, 08:08 PM
You need to actually look at it. The back can be cracked
Old 10-06-2013, 08:15 PM
jethat's Avatar
The gauge sweep is typical of a bad connection. Clean check all connections. You losing power somewhere. They is a possibility it could be the firewall relay you could try shorting the big post to the small one with a screw driver and see if the starter spins. Or just throw one at it. There only about 10 bucks. I've seen this many times and its almost always connectivity..
Old 10-06-2013, 08:17 PM
jethat's Avatar
you do wants check that FPDM on those years they are an issue..
LJByron's Avatar
Ok he can do that tomorrow. Would that cause the check gauges message?
Old 10-06-2013, 08:19 PM
LJByron's Avatar
Seems there are a lot of known issues that are coming up. We just had to have the whole right side rebuilt less than a year ago.
Quick Reply: 2004 ford F150 won't start
