From the looks of the pictures you unbolted the mounts from the frame. The way to pull the engine is to unbolt the through bolt in the rubber that separates the mount into two parts and pull the engine. Are you trying to line things up with the mount dangling from the engine? Or worse the frame side bolted to the frame and laying limp and trying to set the engine down and line the engine up to the bolt holes? I would pull the bolt through the rubber, separate the mount halves and bolt the frame side to the frame, engine side to the engine and set it in that way.
Regards
Jean Marc Chartier
aint gotten that far yet bud
i was having difficulty at first with removing the motor with one stud in the bell housing, it was so dirty i didnt even see it. but before i found that yeah i unbolted the mount from the block and frame. i will be putting the frame mounts back on the frame. i think i bend the drivers side motor mounting plate, not sure how.
i havnt touched the tranny yet, hauled a load with my parents truck and spent a day down there unloading and helping with a neon.
I don't know if this will help - but heres a black one plugged in on my 5.4L . You can see the wire colors. They may use the same colors of your wire harness.
The grey one in this pic looks just like my black one. The sensor behind the grey one doesn't apply. Don't look at that one , that's from a 3.8.
Were the two different in shape on the bottoms that you installed?
Gray with red stripe and light green with red stripe wires are for the Engine coolant sensor (the important one). The connector is gray. The Engine Coolant Sender is the one with the Yellow with red stripe and Red with White stripe wires. The connector is Black.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
lol if it gives me trouble i'll just epoxy that crap in. i figure i can probably lift the whole intake out in 30 mins in one piece now that i figured out some tricks.
