i could put the intake on it and look into the head water passage... it didnt look cut or broke but sure as hell was different!
well i put some jb weld on the spots im gonna drill, i'll take pics of it after it sets up fully.
looks like it'll be fun in the mud when you are all done
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon) old albumshttp://www.f150online.com/galleries/....cfm?gnum=8805
8# since my 4r70w is stock except a shift kit. i wanna let it live as long as possible lol. ya know i decided to do this because i wanted to watch the mud fly, or atleast churn around my tires a lil bit rather than watch the pedal go down without the tires moving.
yeah theres no bolt hole in the middle for it to hit and bolts back up. so im hoping theres a different mount and im not just looking at it retardedly... u spend a couple hours under that truck and you get lost when you stand up.
All modular "motor" mounts are the same, whether its a 4.6, 5.4, 6.8. They are the same, so if you are having alignment problems, then I would say it is prolly the mount.
From the looks of the pictures you unbolted the mounts from the frame. The way to pull the engine is to unbolt the through bolt in the rubber that separates the mount into two parts and pull the engine. Are you trying to line things up with the mount dangling from the engine? Or worse the frame side bolted to the frame and laying limp and trying to set the engine down and line the engine up to the bolt holes? I would pull the bolt through the rubber, separate the mount halves and bolt the frame side to the frame, engine side to the engine and set it in that way.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
