Intake coolant leak& PO307,308
Originally Posted by kenn97
Hello again i'm back, Well iremoved the plugs and they were pretty bad.
In the previuos thread you stated that i needed to update my cop system.
You said that that a set was $85. I'm not really understanding what you are talking about as the plugs are about $40 and the coils are $60 each.Is there something i'm missing? What does updating my cop's include.
Thanks KEN
Thanks KEN
Motorcraft plugs (don't forget that)
COP = Coil Over Plug. That's your ignition type.
Most users @ this site purchase coil sets from this ebay store (Global Automotive) -
http://cgi.ebay.com/ebaymotors/NEW-I...mZ180209220958
I have another question. There is a plastic cover over the lower part of the intake. Well when i took the intake off this plastic cover was very brittle and just broke all to pieces. is this plastic cover needed?Also i ordered the cop's off ebay just waiting for them to get here. Thanks again.
It broke? I think your talking about the jacket - does it have snaps? Mine was rubber and it has two snaps I think - can't remember..I'll try to find a pic - you have a camera?
I didn't see your picture at first, but i think it's the piece under it with the two tabs in your pic,It looked like it was in two pieces and had some kind of insulation under it,It was real brittle and just sort of crumbled It covers the top of the plastic lower intake.Im getting ready to put the intake back on but not sure weather i should without this cover.Also it must have been the o rings in the tube that was leaking because the tube looked good.So i'm going to put some new o-rings in it and move on.Also on your pic does the o-ring and gasket in the lower intake were the elect. plug plugs in need to be changed wile its out?
Actually my gaskets looked good on the lower intake so I didn't change them - I didn't have any at the time either or I would have - It's always a good idea to change the gaskets - If you don't , make sure you clean them up well if their in good shape.
I didn't bother replacing the o-rings on the water pump stem because Ford doesn't - I read that somewhere and if you have a Haynes or Chilton's book - Look in section 1 , they show a picture of a Reman block with the Ford fix. They use heater hose and don't bother replacing the o-rings because they don't last don't last..
BTW - Those gaskets must be "oil free" on install or they may leak. All surfaces and gaskets themselves must be clean and dry.
Similar Coolant leak Problem
I have a similar problem. Whenever I give it gas it started sputtering and hopping around and the idle was pretty rough. Took in to the mechanic I always use and they determined it was a leak in the either the head gasket or intake gasket and the leak had shorted out one of the coil packs. They replaced the coil pack and gasket, thermostat and flushed the radiator. Ran great for about 2 weeks and now the problem is back. I replaced the plugs with Motorcraft plugs (again) just to make sure that wasn't the problem, checked the injectors, checked the oil for coolant and nothing. Can't see any coolant leaks but the engine is sucking gas like it's just blowing by. The problem started at exactly 149,998.6 miles.
