F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #91
Old 09-30-2007, 06:06 PM
Vehicle: 1998 Ford F150
Ok I bet the wiring harness is bad because I tried using my ac which is also a wire off the harness and it doesnt kick on...
  #92
Old 09-30-2007, 07:07 PM
Vehicle: 2000 Ford f1504x4
Yup that will do it!!Hopefully you have another harness or can find the bad spots with that one!!I assume it is a used harness you got with the lightning take-off.
This kinda sucks,now we prob don't get to hear it run
  #93
Old 09-30-2007, 07:45 PM
Vehicle: 1998 Ford F150 4x4 5.4L
I thought your AC went out awhile ago when you heard that hissing noise - like air leaking. That was some time ago tho , you may have fixed it - don't know , you posted that and I think others posted as well it was prolly the AC. I remember waiting for a post about what the problem ended up being - but you never posted it .
I heard air pressure exscaping in the past and it ended up being the AC failing ..
Easy just checking if voltage is getting to the IAC or a continuity test on the proper harness line itself. Might be missing pins on the other side of the harness as well. Truck may not be wired to receive a lightning harness. - idunno?
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/Amsoil EEA191 Filter, 265/17 GY Fortera's.
  #94
Old 09-30-2007, 11:46 PM
no i have no idea what made that noise, but i put my factory harness back on and had to extend several wires, but no more codes, and everything works like it should, but still wont idle... im uploading the videos now
  #95
Old 10-01-2007, 12:03 AM
DANG - does the MAF look okay?
  #96
Old 10-01-2007, 12:07 AM
yep, it came off a running lightning... Here is the first start video!
  #97
Old 10-01-2007, 12:10 AM
Yea the weird part about it, it was a brand new lightning harness... But my factory harness is working like it should, but it still wont idle, has to be in the tuning...
  #98
Old 10-01-2007, 12:20 AM
By the sounds of it , your prolly right. It sounds good , so far - Like Normal , for a kicka$$ powerplant.
But , have you had it running long enough to heat up the O2's? I don't think it will matter the way it just goes down to nothing , it might a little if it's not to far out..I bet your right about the tunning.
Still could be the IAC stuck shut..Usually it will idle super low when that happens- hard saying in this circumstance..??
  #99
Old 10-01-2007, 12:26 AM
yeah i drove it to auto zone to buy some stuff. I gave it almost 1/2 throttle and it boosted to 15 instantly and talk about some G's! then it blew the fuel pump fuse and died... I figured the engine seized lol but i saw that fuse then later realized i didn't have the tps wire connected to the fuel pump controller, which blew the fuse. it runs so smooth on the highway, sounds really good too, it sure does crackle a lot when i let off the gas, that makes me think something is up with the tuning too. And for the stall converter, it feels like a new tranny, it holds so tight. the wine from the blower is amazing :| I put it in neutral and revved it by a gas station, made everyone look lol. I haven't had it past 3500rpm though, i cant imagine how it will run and sound when im slamming the gas!
  #100
Old 10-01-2007, 12:29 AM
AWESOME!! - Congrats so far Joey
  #101
Old 10-01-2007, 12:32 AM
Oh and one more thing, I must have got the float on the fuel pump against the tank, it wont move past 1/8 tank o jeez more work ahead. Oh and for some reason the coolant sensor isnt working... and I think the knock sensor needs replaced, long story, So tomorrow ill probably pull the whole thing back off and replace the knock sensor and see whats up with the coolant sensor... anyone have any idea what a sign of a bad knock sensor is??? also, my headlights come on with my parking lights now...
  #102
Old 10-01-2007, 12:40 AM
Ok here is a better video!
  #103
Old 10-01-2007, 12:46 AM
Quote:
I think ill check that tomorrow, but I have the tuner idle set at 980 in neutral, and i can get it to idle at 500, and 860 in drive, which actually idles at about 550-600, but it will die when i come to a stop if i dont touch the gas. I know its nothing serious, the engine runs smooth as can be, and has great oil pressure, im still happy
  #104
Old 10-01-2007, 12:47 AM
That Blower sounds wicked!! She must really fly...
  #105
Old 10-01-2007, 12:50 AM
40 miles so far! just thought id let you all know
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
