F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Thread Tools Display Modes
  #196
Old 10-04-2007, 09:18 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
Quote:
Originally Posted by built54
no, it is getting way too much, but I just got some new wiring instructions from Mike, so lets pray it works
post these for others like me who will probably run into the same issue later.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #197
Old 10-04-2007, 10:15 PM
Send a message via AIM to Faster150
actually the brake booster is ran off vacuum from the upper plenum, it works fine. Im using the lightning rail and reg.
thats true lol nm than. i dindt remember untill i went out in the shed and looked at my plenum
  #198
Old 10-05-2007, 12:46 AM
Vehicle: 1998 Ford F150
Ok UPDATE! Its alive! it idles! Talked to mike for a long time, came to the conclusion my controller for the fuel pump is faulty. We figured out how to bypass it and still get a dropped voltage for my pump. I got it all figured out. Went to start the truck, would not run still, no power, *&($&^ yea i was really mad. I decided, I have to know what the fuel pressure is. Went to autozone and all they had was a tester for 92 and older fords. hmm.. It has to work, got home, it did work. Put it on, turned the ignition on/off 3 times, NO pressure at all! hmm that cant be right, i took the tester off and pushed in on the pin in the shrader valve, just kinda puked out, no pressure. Ok so this is great news to me. I go to the fuel filter, pull that line off, no pressure, fuel just dripped out. ok, got to the pump, no pressure there. Took the tank off for a 3rd time. Pull it out, it all looks ok. I blow in the outlet end of the pump and fuel dumps out between the threads on the line going to the pump, its about ready to fall off! I tighten that and reinstall it. well I dont know what I did, but now my float is stuck and reading 1/4... great, I have to take it off a 5th time, but not now! I put the gauge back on and it read 42psi at idle. It runs great, idles great, but it still cuts out in boost. I'm sure its just in the tune, it has to be. I'll do some more data logging tomorrow.
  #199
Old 10-05-2007, 01:14 AM
Quote:
Dont hold me to it, but I'm pretty sure Mike wont be selling any more of these controllers. He will switch to a new style. He also includes the correct wiring diagrams with the controllers. I will get that engine swap writeup to you soon dont worry, i've just been WAY too busy
  #200
Old 10-05-2007, 01:46 AM
oh im gonna hold ya to it! :P
so part of your issues was your fuel pump install didnt hold together well enough? keep us posted how it holds together.
  #201
Old 10-05-2007, 06:43 AM
Vehicle: 2003 Fast Screw
Your doing great Joey,,don't let it get ya down!
It took quite some time before I ever got my setup tweaked to perfection,,,lol.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #202
Old 10-05-2007, 07:56 AM
Yeah, baby!
Gonna have to call ya Mr. Persistent, the fuel tank R&R Expert
Go, Joey!
bubba
  #203
Old 10-05-2007, 09:27 AM
Ok the li ghtning guys are telling me my tuner can adjust the maf for the 42psi at the rails, since it is currently tuned for 39. I hope!
  #204
Old 10-05-2007, 09:30 AM
Oh and yea, its pretty bad when I can have the tank out, pump out, with half a tank of gas, in less than 15 minutes...
  #205
Old 10-05-2007, 09:46 AM
You mean MAF / injector size scaling right - yes he should (as you saw in those earlier links I sent ya).
So - he's got to plug in te CORRECT value files for the BA2400, and then scale it for 42lb injectors...
Man - he should have done that from the start
And there is no way in HELL the STFT's were in the green - no way.
bubba
  #206
Old 10-05-2007, 12:54 PM
Vehicle: 1998 FORD F 150
Nice time!
Look at the bright side, your tank is probably super clean by now with all of the road grime in the laundry basket! Keep up the good work, your'e getting there.
  #207
Old 10-05-2007, 04:22 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Hey Joey , when you get her all up to snuff (sound like your getting closer) and all dialed in - Do me a favor - Floor it from a stop and see how fast you get to 80...
I'm just curios how much faster my 98 is ..??
Thanx ..
Was rear ended this morning and my front driveshaft back home - haven't got it back on yet..
Rear tires were up in the air couldn't get any traction - Stuck on top of this a chicks Saturn - First time the front shaft has been off since I owned the truck and I end up needin it
Peeled that little Saturn's hood like a can opener - everyones okay - I think that chick filled her drawers - she was freakin a little - Knocked a little rust off my frame - The Saturn stopped about 18" from my rear axle..
Goofy woman , talkin on the cell phone..At least she admitted it - she could of been prettier - oh well ..- Stuff happens.
Keep goin dude , almost there , can't wait for the vid .. That things gonna freakin FLY
  #208
Old 10-05-2007, 07:14 PM
Vehicle: 03 4X4 5.4 SCREW
brew, glad to hear you and the truck are ok and keep diggin built54, this gonna be a great engine/truck
  #209
Old 10-05-2007, 08:08 PM
damn jim! lol stupid women on their phones.. i got rear ended by a focus. years ago who was on his phone.
1997 F150 175K and counting
P1SC, Full Bolt-ons, and 91 Tune with 10* Timing @9psi
est. 367hp 366tq Mustang Dyno
new times coming soon!
tuning by Neal "The Car Shop" Temple-Killeen, TX
  #210
Old 10-06-2007, 02:08 AM
Well I'm just waiting now. I washed my truck for the first time in a month today! Thats a record. besides that, nothing really changed. It will idle really good and revs great, still sounds mean, but waiting on a tune tweak.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
