4.6 Timing
Old 03-29-2007, 09:09 PM
kirk7983's Avatar
4.6 Timing
Can anyone give me some help on getting back in time.
I let the left side timing chain slip.
Now I'm not sure how to set the timing on that side.
The right side is still in time.
This is a 2000 4.6 engine.
Thanks for any help!
Old 03-29-2007, 10:26 PM
torkum's Avatar
Do a search, I have seen details here or maybe jbrew will post some of his kool diagrams.
Old 03-29-2007, 11:13 PM
jbrew's Avatar
As long as you didn't move the crank at any time , you should be able to get it .
This is the 5.4L set up , I'm not sure this will help you , but it may -
Below is were the copper link should line up on the right side - marks between , I would set the lft in relation , comparing the diagrams to your setup should tell you if this will work for you ..I dunno , but I could tell if your motor pics were in front of me..
Just a few diagrams that may assist you here -
Old 03-29-2007, 11:21 PM
jbrew's Avatar
A few More -
Neal posted this pic awhile ago - it may help -
Best I can do hope it helps , Good Luck
Old 03-29-2007, 11:32 PM
jbrew's Avatar
I found a 4.6 diagram on a 99 CD they are the same from what I can tell , you sould be able to use these -
Both sides are the same , use the copper links to to center marks on the crank and camshafts ..
Like I said , as long as you didn't turn anything - it should be easy to put that chain back on..:o
Old 03-30-2007, 01:23 AM
ruger43's Avatar
When you are finished getting it timed, make sure you can rotate the engine by hand a couple of revs to verify there is no piston to valve contact. If there is not any contact you are good to go.
Quick Reply: 4.6 Timing
