spark plugs
Dont' bother with either of those, bosch 4's are crap in american trucks. Use any single platinum or the denso iridium if you want the increased performance. You have to be able to gap the plugs to install properly, so no bosch 2's or 4's. No, replacing earlier than scheduled won't help you much, unless you upgrade the igition, i.e. coils and iridiums.
on
If you have a 2005 then there should be 3 engine choices. The 4.2 V6 and 4.6 V8 which both use ordinary plugs and are relatively simple to change. Any major brand of your choice with one ground wire, not the +4's that Bosch has, and you will be fine. Double platinum plugs are a good choice and last longer than all the other types except for the iridium ones. If you have a 5.4 it has a special plug that uses a loop for a ground wire.
If you look closely you will notice that the plug is extended. The design of the cylinder head requires that the plug be of this design. It sits in a recess in the combustion chamber and this area below the plug threads can get carbon fouled. When this happens the plug jams and breaks. You are then left with a mess that requires special tools to remove the plug without pulling the heads. For normal removal and replacement Ford recommends a special procedure that involves penetrating oil and loosen / tighten to break the plug free of possible carbon build up. I would recommend removing the plug every 25,000 miles just so that the carbon doesn't build up. Maybe a motorvac treatment to keep the carbon away too.
JMC
JMC
Originally Posted by rb4123
Anything Bosch is pure junk.
