EGR question
EGR question
A while back my 98 4.6 had a pretty serious exhaust leak where the EGR tube connects to the exhaust manifold. The fitting that screws on to the manifold had almost completely disinigrated <sp?> due to rust. Well I replaced what I needed to, to stop the leak, and recently I have been trying to diagnose the rough/stumbling idle that alot of F150's seem to be plauged with. My question is, would a leaking EGR tube (for almost 6 months...maybe more) cause an EGR to go bad? and I have since replaced my EGR valve position sensor as well.
Thanks in advance
Thanks in advance
I'm with bluegrass on this one. If the EGR wasn't working, it would have set a code.
Try spraying starting fluid on vacuum hoses around the engine compartment at idle. Listen for any rpm changes. A common source of vacuum leaks is the rubber elbow where the pcv hose meets the intake manifold. I'm not particularly sure about your model and engine, but it probably has something to that effect. You could try cleaning the IAC valve as "torkum" suggested, as they are known for causing trouble, but I'd look for a vacuum leak first.
