Motor mounts (in the middle of pulling)
Old 03-14-2007, 03:23 PM
we287gn's Avatar
Hey all, hope some can shed some light..
I have the tranny unbolted and lift attached to engine, all i have too do is remove the long motor mount bolts,.
they seem to be turning very hard, and i cant get a decent tool in there and have enough leverage to work it out..
Is there a trick i am missing, is there a better way to get in there
i am currently trying to get on them from underneath, but its pretty tight..
i hate to do it, but i may break out the air gun and use the swivel attachment..but i am holding off for now
thanks
Chris
Old 03-14-2007, 03:44 PM
Klitch's Avatar
spray lube or heat used yet? try using some lube and work it into the threads.
Old 03-14-2007, 03:58 PM
we287gn's Avatar
Hey Klitch, thanks for the reply,
they are free, feel as though they are riding inside the rubber of the mount, just very tight..I have soaked em down in PB blaster, just a very rough spot to get hand tool movement..
actually the threaded section sticking out is pretty clean, suprised me actually..just figured i was missing a way of getting at em
thanks
Chris
Old 03-14-2007, 04:12 PM
Klitch's Avatar
mmm pb is good stuff, just a tad smelly.
unfortunately i dont think there's much you can do about it if thats the case... unless you can work the pb in deeper by exposing threads, spraying them and tightening it some.
Old 03-14-2007, 04:29 PM
we287gn's Avatar
guess this one will be a slow process, funny i saw the question bout the 86, now its gone
had to look up the cubes i had forgot, 420cid
its the IH diesel motor, wish it had a turbo and a 5th gear though :-)
thanks
Chris
Old 03-14-2007, 05:08 PM
Klitch's Avatar
lol yeah i had a realization the 390 was not 6.9L lol
it was somethin like 6.5
yeah, its gonna be a slow job until the end.
the only thin i can think of is there is still stress on the mount in some direction holding u back
Old 03-14-2007, 06:45 PM
JMC's Avatar
JMC
JMC is offline
Make sure that you have removed all the weight off of them. If the engine is not lifting straight there may still be loaded. If you have access to an air gun then that is what you should use. Why F around with hand tools when you have air?
JMC
Old 03-15-2007, 04:06 PM
we287gn's Avatar
JMC
Hey Klitch,JMC, its out!!! yay
a bit tight, only knicked the condenser fins a couple time, pretty sure there are no holes
left the hood on too, so that was cool, only thing that got snagged up but not wrecked thankfully was the engine harness and main fuse buss, if i had know i would have tried to move aside
ya i tried gettin a bit of the load off with the lift, finally i used a bunch of extensions and was able to get the power too it.
I guess even with the impact i would have had to use extensions..
i know it seems silly i didnt try the air right away, but i would have had to lug out the compresor and run a chord, i know stop whining..lol, any way its out
and thanks to all of you that have been responding with all the help and advice
now to get that core plug in, and freshen up some gaskets and seals..
Chris
Quick Reply: Motor mounts (in the middle of pulling)
