Synthetic Oil
Synthetic Oil
I just purchased my first F150 06 Screw 5.4 3V.I do alot of city driving mostly stop and go.Some of my friends tell me I should change all my fluids like Rear Axle,Transmission,Engine,and Power steering over to Synthetic because it would be less friction and everything will last longer.I have to keep this Truck for 10 Years. Is this information correct or are they clueless?I value your advice. Thank You.
Originally Posted by ()smoke()
good synthetic motor oils are generally better performers under high heat conditions...
If you change your fluids religiously at the "severe service" intervals listed in your manual, you should have no problem whatsoever in getting 10 years/200k miles of service out of your drivetrain -- so long as you don't abuse it in other ways. No need to use special synthetic lubricants -- the Motorcraft variations of these products (or other high quality brands) will serve you quite well. Leave the "boutique lubricants" for the guys who get some sort of bizarre thrill out of making oil more complex than it really needs to be!
I have a preferred membership and order it online, from vegas to socal shipping takes about 3-5 days and I get about 20% off all orders. If you were local I would order ya up some if you would like the membership its $20 a year or $10 for 6 months and you get access to all of their items EVERYTHING! And its cheap...well cheaper.
https://www.amsoil.com/storefront/Se...CategoryID=286
Your 06 Ford already has synthetic fluids in the rear end and transmission from Ford. Transmission fluids from the manufacturer will always be far better for transmission life than an after market blender that makes a fluid that gets in the ballpark with friction coefficents but never is on the money as per design perameters. Engine oil......as long as it meets Fords 930 spec, you won't find a better oil regardless of price or advertizing hype. Your money, your truck.
