5w30 or 10w30
Nevermind 10w-30, many say going to 5w-20 from 5w-30 is best because it gets into the heads better would be the way to go. Everyone has their own rationale behind oil and preferences as to brands and weights and blends. Again, as long as it's maintained proper, there is nothing more you can do. Going to 10w-30 is OK, but keep in mind that oiling to the heads requires thinner oil to be ideal. My uncles 99 merc gets 10w-30, why? don't know but it was fine, I then changed to 5w-30 and she never missed a step. Just my spare change ($0.02) on this subject.
Originally Posted by KDOTengineer
Does John Deere mark up their oil and filters 200% like everything else they sell?
But, actually no. The oil filters are the cheapest I have ever found. And the engine oil is only a little bit more expensive than napa. But my truck doesn't burn it as bad as it did the napa. It doesn't seem to lose its viscosity as fast as the napa stuff, or motorcraft, and that's why I run it. It comes out just as thick as when it went in.
As for whether or not their oil is better.... I don't know for sure. They REALLY tout it, and the machines do tell a difference. (as far as using oil) JD also allows you to extend the regular oil change interval from 100 hours to 350 hours just by running it. Obviously this might be a marketing technique, but it REALLY isn't that expensive, I think it's just over $2 a quart... And 350 hours is an eternity for a dirt eating WOT running diesel engine.
It may not be the best, but it's good oil. My dad saves some of the used oil out of the tractors and pours it into all the little 5 hp engines we have around the farm! I took a pic of that a while back, and I was just saving it for the right moment. I was hoping it would be in an Amsoil or Mobile1 thread but......
Ford has recommended all F150 gas engines from 97' to present to use 5W-20. Even if your manual say 5W-30, Ford has issued a maintenance bulletin that supersedes that recommending a change to 5W-20.
Don't start saying it's because of fuel economy CAFE numbers, because that only applies to current vehicles for sale. Ford wouldn't risk reliability issues on older engines, so there has to be a reason for Ford recommending 5W-20 for old engines right?
After speaking with both a Ford engine tech and an independent Ford mechanic, it seems that the 5W-20 lubricates the upper-valve train better than 5W-30.
These modular engines are tighter in tolerances, and the 5W-20 works really well in them. Hence Ford recommending all modular gas F150 engines from 1997 to present to use 5W-20.
