Throttle Body Size
Throttle Body Size
Does any one know the diameter of the throttle body on a 98 4.6. And does anyone have an after market throttle body. HOw well did it help with power?
Also what is having one ported and polished and does it help?
Im looking at doing somthing behind my intake to help more air.
so pretty much what your doing is just boring it out more than it already is. No switching of the elbw or anyhting? Can i do the smae for the throttle body. Im a machinest by trade to i have all the tools to make a new throttle plate at work. If i could bore the throttle body and elbo then make a new plate that would give me more flow. What about sensors?
I can do that. I already manufacture the ones for the jets the navy flys i think i can do the one for my truck. What im worried about is sensors. Will that change how my MAF reads?
HI!... If your talking about boring out a TB spacer don't bother. Been there done that, dynoed that, lost H.P. TB spacer don't work. It's a concept for carbs that works very well but on F.I engines it is useless where the after market company's put it. It doesn't do anything for you between the TB and TB ELBOW.
Also if your going to bore your factory TB out to a larger bore make sure you make a new butterfly as well. Also the butterfly is not round. It is slightly EGG shaped and has opposite cut backs at both ends.
