knocking and pingging
it is not throwing codes. i picked up two coil packs today and will get the injectors this week. it has new plugs and wires. it idles fine. tps switch? i was thinking about a loose ground wire for the fuel pump. i go over rr tracks and it sputters
Yeah , all your O2's are fine - those codes prove that there working as they should be. You have a vac leak most likley or a dirty MAF sensor.
Check the hose that 90's before entering the rear of your manifold - it's been a common problem .. This one -
Clean your MAF sensor.
It's in here -
It's in here -
