What have you replaced????
What major problems have you had and what have you replaced to keep your truck livin on a little longer?? My 97 f150 has 156,000 mi and I just replaced the u-joints and the ball joints on the front end? How about you? I want to know what I will be changing in the near future.
I had my 97 F-150 5.4 motor and 107,000 when I bought it. The only thing that went out on it in the year I owned it was the PCV Tube. Traded that in December of 06 for an 05 F-150 5.4 motor good thing it is still under warrantee because the 4 wheel drive has wen out twice I have put less than 4,000 miles on it. And the Cam Phasers need to be repaced. If I could get my old truck back I would do it in a minute.
At 310,000 miles my 97 4.6 has had:
The differential bearings: carrier/pinion (8.8") at 200,000 miles
U-joints and center carrier bearing 210,000 miles
one alternator at 285,000 miles but had bearings at 160,000 miles
DPFE last week
Both outer manifold y-pipe studs
Lower ball joints at 275,000 miles, rest of front end is original
Some dash lights
Corroded through + battery cable at the starter.
Current issues:
Sometimes intermitant wipers don't work right. GEM module?
Some dash lights. If you change one change them all!
Rearmost exhaust manifold studs are broken causing a small tick until the exhaust gets warm then they seal up.
Broken drivers lumbar mechanicals
The fuel and brake lines under the truck are very rusty. I will be painting them with grease to stop the rust.
I'm amazed at the life of the front end parts and that the water and fuel pumps are original. It's had three tune-ups but only replaced the plug wires once. Only replaced the accesory drive belt once. 4 sets of tires. 3 sets of front rotors on about 8 brake jobs. Rear shoes once on original drums. Add a quart of oil about every 1200 miles. Great truck. Hope to see 400K miles
DPFE last week
Some dash lights
Current issues:
Originally Posted by keith97xlt
hey bent. 310k?? you definitely got your moneys worth out of her. i would replace all your brake lines. steel lines are not that expensive. putting grease on them wont really help much. the lines will rust from the inside out. old brake fluid attracts moisture aka rust.
you cant buy factory lines from ford. if you bring it to the dealer for example they just go to napa or autozone etc.. and buy from them and just bend them up. i did my whole truck in about 6 hours. some pb blaster, plumbers type propane torch. and good set of wrenches and a cheap 10@ tubing bender.ive had a hard line burst on my old dakota it sucks. trust me it worth doing ,especially if you need 3-4 more years out of her.
