funny feeling in rearend
hey guys, the other day i noticed that sometimes when im at a dead stop and i start accelerating about half way, it feels like the passenger side rear like makes a grinding feeling but without the noise. it only does it sometimes and maybe for about a second or two. hope i explained it good enough for some responses... thanks for any help guys
If thats the case you may want to get that looked at sooner than later. A new diff isnt the cheapest thing to purchase and get installed.
Also your post title is rather humorous in a very juvenile type of way, couldn't help but chuckle for a sec upon reading it. My first thought was "Sounds like a personal problem."
HI!... Try doing a rearend service. Change the oil, check for any debre in the oil and down in the case. Inspect the clutches. I tore all the "THUMB NAILS" off most of my clutches in my 9.75 a few years ago. Remember to use synthetic gear oil and most importantly remember to use the FORD friction modifier with the gear oil.
What kind of rear-end do you have? Limited Slip? What kinda gears are you running? Did you replace any of the gears for a higher/lower gear ratio?? I am definately no expert with differentials...etc. but I get the inner workings of them. Answer these...reply back maybe someone can give you more options from there
~Phil
P.S. Thats what she said
~Phil
Yeah, I had to do that to mine , although I didn'tdrive in circles , maybe I should have, it may have totally healed quicker ..
Anyway after changing the the rear end fluid the prob almost disappeared completely - it took about 50 miles or so for it to completely go away, but it worked!!!
Oh , make sure you add the friction modifier to the 75w 140w mentioned more than once above , they say 4 oz's for the 8.8 rear end and 8 oz's for the 9.75's.
Good Luck
Good Luck
