coil pack bolt HELP
coil pack bolt HELP
Had to clean some moisture off #7 plug and coil. I ended up cross threading and breaking off the head of the bolt that holds on the coil pack. Did not realize because my universal joint on my socket was leaning on the diaphram above (on fuel line? I believe. Any ideas??. If I have enough bolt would it be worth just trying a 7mm nut?
If you have enough threads sticking out, after you remove the COP, double nut what is left of the bolt and remove it. Then, retap the hole with a 7mm tap. You may be able to save some of the threads. Remember, you don't have to apply the force of God to snug the COP down onto the intake. It needs to be tight enough so that it won't vibrate loose, but loose enough so that the bushing can rotate a little bit.
If there are not enough threads left in the intake then tap it a little bit bigger.
If you are just going to pull the whole intake, a whorthwhile mod may be an Allen supercharger.
I would suggest getting out the remainder of the bolt however you can (double-nutting as above would be a good first try).
After out you can chase threads with a tap and I would be suprised if there weren't enough threads to allow it to torque up. That bolt is retty long it may have only messed up the threads up top.
Also, I have used thread forming compound from loctite in the past on low torque bolts like this.
If you salvage enough threads to torque up I would also suggest using blue loctite when you install as a preventative measure to keep it from backing out.
If threads are destryoed, pull the intake and time sert, or time sert there if you can get to it.
My 2cents.
Andy
My 2cents.
Andy
