Rear axle seal leaking
You pumpkin might even be empty!!!
Break down the side its leaking(tires/caliper)
Open up diff
unbolt the pin
push the axle it self into the diff
snag the C-clip out
pull the axle out
change seal
put axle back in
put C-clip back in
bolt pin back in
seal up the axle.
fluid is 75W140, about $16 a qaurt from Motorcraft with a $5 fricton modifier
Open up diff
unbolt the pin
snag the C-clip out
pull the axle out
change seal
put axle back in
put C-clip back in
bolt pin back in
seal up the axle.
There are alot of factors when it comes to cost. Basic seal replacement would be about $200.00 at a shop. If the axle has a groove in it where the seal sits, it may not seal and still leak and axle will need to be replaced. Depending on how much oil is on your shoes, it could be cleaned using brake cleaner
