98 5.4 just dont have the kick it use to
ive had this 98 f150 for 5 years now and just recently ive noticed that it just dont have the *** it use to ive performed regular maint. on it such as plugs and the typical coil packs that keep failing.i dont know if the engine is the prob or if theres an issue with the trans.i say the trans because at times it just dont feel the same it dont slip but it shifts odd to me ever since ive had it.take for example times when it should down shift it upshifts like when someone in front of you slows to make a turn and you go to accel. it will up shift instead of down shift.and when it does this you have push the throttle down further and when you do that its like your trying to abuse it just to pick up speed i dont know whats wrong with it.is there anything i can do to get this thing to come back alive any input will be appreciated
Just some questions for yuh..
well my truck is 4x4 ive installed a k&n air filter.with magnaflow exhaust with stock converters these items have been installed for a while recent repairs have consist of new fuel filter about 3000 miles ago #4 coil pack,idle air control and just changed the oil with mobil one syn i have 135000 miles on my truck and i have shifted it manually before and only result of that is it revs higher but still dont put you in the seat like it use to hell for example i got out ran by a buick regal with a v6 that was sad and i know this truck has better performance than this because it was alot quicker than this ill try cleaning intake system. any particular cleaning proceeder for this and ive changed the trans fluid and filter do i need to take it and have them flush the converter.im running autolite plugs whats the best for these engines.is it time to replace the injectors it dosent have any missfire but ill try these things and see what happens and soon as i find out ill let yall know
replaced one o2 sensor on the right bank closest to the engine.dodne this about 5000 miles ago.also i was considering removing the whole exhaust and running true duals with two chamber flowmasters i know there will be an issue with the o2 sensors what needs to be done to make it work and will this kill it even worse hte engine dont run hotter than usual like a converter is stopped up but they've never been changed either.only thing that ive noticed a difference is that the engine does not start like it use to for example during cold starts when you crank it over youll get to the point where it is fixing to start and you let off the key it will go dead as if you didnt let it crank long enough.then when you start it again it starts fine dont know if its got any thing to do with the low power but just trying to think of all symptoms i have.i just had to replace the radiator so i havent had a chance to try those things listed above but i got a free weekend to do them and see what happens
