codes for check engine light?
Originally Posted by Sullman20
Just drove 700 miles with no problems and at the end of the trip,my check engine light blinked about 10 times and now stays lit.how do I retreive or "read" the codes to expose the problem.Thanks
Mike
on
Even if they do try to tell you what they mean, just WREITE DOWN THE ACTUAL CODE numbers, then come back here and do a SEARCH for those codes to see previous discussions on what they mean and how to correct the faults. Most common fault codes are well-documented here and elsewhere.
Under no circumstances should you let the monkeys at the parts store try to diagnose the actual fault unless they will accept responsibility for incorrect guesses.
If you are not encountering any noticable drivability issues, the fault is going to be emissions related.
Steve
Steve
Originally Posted by mgsalida
You can take the truck to Auto Zone and they should be able to hook up a scanner and tell you what the code(s) is(are). Make sure you write them down. I don't know if they will tell you what they mean.
Mike
Mike
