2005 PCV location
2005 PCV location
Working on a problem with oil being sucked into the supercharger. Problem is where is the PCV located? I have a pressed-in-cover fitting on the DS cam cover and the black fitting that was located in the intake. Neither appear to have any inner workings (just fittings). Anyone got the manual?
Thanks!
Thanks!
There isn't a PCV, it's just a restrictor under the pressed in fitting on DS valve cover.
One place to look for a problem is the hose on the PS valve cover. I saw one that was partially plugged and caused the crank case to go under a bit of vacuum. This restriction was due to excess flashing when the fitting was pressed on the plastic tube
The stock intakes are known to have oil accumulate in them, nothing wrong there.
The truck I had with the bad PS side hose I found kind of by accident. With the engine running it was hard to get the oil fill cap off and when it came off I could hear the vacuum escape.
That hose is where the PCV system sucks clean air in so you shouldn't see any oil there.
