air fuel gauge install
an A/F gauge absolutely needs O2 sensor input, so if slaving off an existing one is a problem you can get another o2 sensor that you just drill and install in addition to the factory 4.
http://www.innovatemotorsports.com/products/MTS.php
IMO, you're going to run into the same problem regardless of where on the harness you tap into the o2 sensor. The o2 sensor is a low voltage signal, and by tapping into it, you are giving an alternate route for the electricity to go. this is going to affect the signal the computer reads. I really think that an independent o2 sensor, or sensors is needed. On that site I linked to, it has a lot of information explaining how the system works. You would have to have mulitple sensors if you want to know how the whole engine mixture is, since just one sensor only gives you one bank, or 4 cylinders.
HI!... Sounds like you are trying to install a NARROW band A/F gauge. If you are, don't bother they are junk and totally useless. Get yourself a WIDEBAND A/F gauge like one from INNOVATE MOTORSPORTS. It comes with it's own WIDEBAND O2 sensor. 100 times more accurate and won't be going crazy like the NARROW band gauges do.
