Cold start whine
Cold start whine
Has anyone else had a whine on the cold start up on their trucks. I don't think it matters what size but mine is a 4.6. If it is very cold (-30'C) the truck makes a whine immediately when I start it up but it goes away after a few seconds. I'm kind of thinking power steering pump but I am not sure.
thanks,
Bill
thanks,
Bill
Might want to take the belt off and start it up a few seconds to make sure it is external. After you shut the engine off and before putting the belt back, jiggle all the pulleys to check for excessive play. If you find the power steering is the problem you can add a little tranny fluid or friction modifier.
Originally Posted by stein78
My 5.4 does the same thing. I also think it sounds like the power steering pump, the fluid must be like molases when it's that cold and takes a bit to get moving.
I also have that sound on my 03 4.6. Like you originally stated Bill it only happens when its cold.
I have always heard some kind of squealing on cold motors. I just chalked it up to the thick fluids and ice on the belt from the all the slush/water/snow being sprayed up on the engine when your driving. As the Engine cools it freezes where ever it lays.
I use a block heater at those temps and it doesn't seem to squeal as often after i started plugging in at night. Although I must say the factory block heaters don't get that hot. I had one on a taurus and the snow didn't stay on the hood except for in patches!
Long story short....its nothing!
Originally Posted by Paratrooper
Has anyone else had a whine on the cold start up on their trucks?
Originally Posted by mrinaldi
Mine has done it since new.....2000 5.4.....when its very cold out, on startup, a loud rrrrrrrrriiiiiiiiiiipppppppp, for a second or two, than its gone,
SL
