Fuel Filter???Missin,But no Engine light???
My 2001 supercrew is missing everyonce and while not all the time.No check engine light on!!It bucks and misses when Im excelerating like 50mph!!Would this be a fuel filter issuse?If you rev it up it dont miss or anything???Thanks for the help.Thanks
A clogged filter or restricted fuel flow will usually cause problems when the engine is under a heavy load. Accellerating at highway speeds puts a heavy load on the engine. Lots of rpm in neutral or in a low gear does not load the engine as heavily as when you are accellerating in top gear.
So it sounds like a clogged filter is definitely a possibility.
They are cheap and very easy to change with the right fuel-filter tool, so it makes sense to replace it.
Here is a link:
https://www.f150online.com/tech/fuelfilter.html
And another, showing the filter line removal tool (same one I use)
https://www.f150online.com/forums/sh...rake+line+tool
Don't even try to get the lines off without the special tool (I got the Auto Zone set for like $10). It only takes seconds to remove with the right tool.
Here is a link:
Originally Posted by torkum
If the fuel system checks out ok, look at the trans.
