What oil do you run? Higher mileage trucks?
Originally Posted by 98triton54l
I use valvoline maxlife 5w30 or motorcraft 5w30 but mostly max. as long as you're still changing it regularly at scheduled times then keep doing what you do and drive it.
That mileage still amazes me 400,000
I use 5W30 Mobil, not synthetic. Seems to work fine. Just like 98Triton said, keep changing it regularly
less friction = better gas mileage and longer engine drivetrain life
I am looking to increase gas mileage 2 to 5 miles per gallon. I recently installed a full flow Lifetime oil filter with stainless mesh filter ($100). I intend to change out my engine oil, front and rear differential gear lube and tranny fliud with the Amsoil products. Folks are claiming greater HP, smoother running engine and 25+k between oil changes while improving petrol consumption by 2+ mpg. The differential fluid should last the life of the vehicle. I am also considering 250,000 mi. propylene glycol coolant to prolong engine life and benefit mpg. 18 mpg just doesn't cut it anymore. I will post my findings later.
