Losing power more every day
97' stock F150, 4.2. Haven't done any troubleshooting yet but will begin tomorrow with a compression test. Losing power and need to downshift going up small hills on the interstate at 70 to 75 mph. Other symptoms which may be clues are: odd put-put sound from exhaust at idle; continuous small amount of coolant loss. Oil and coolant remain clean. The engine runs smoothly other than the recent power issue. Does this sound like a head gasket as some have suggested or a clogged converter, maybe carbon build up? Concerned it may be a valve due to the exhaust sound. This truck does mostly highway travel, regular oil changes, moderately well taken care of.
Thanks for any help.
Originally Posted by Jdm28j
Ive got a 97 4.6L with some what of the same issue but mine loses power when im in 4th but mostly 5th gear. I dont have the noise or anything else coming from the exhaust just the power lose when going up hills and such in gear. I would also luv any help that can be given.
Originally Posted by sfam198
if i understand you right, you're trying to climb hills in overdrive? of course you're going to lose power and slow down, try downshifting to 4th or 3rd gear.
No ur correct and I understand that, but its like when I want to give her gas even on a straight road and a slight alittle incline its if she doesnt want to go even if I push down on the gas peddle. She just loses speed and has no pickup.
coolant loss everyone!
