electric fans cooling
Originally Posted by avey
the two fans are 14" and the motor is 4.6. where do I add sensors for temp and ac
Typically, the controller will have an input from a thermister that is inserted into the radiator for turn-on control. Some have a probe that actually gets installed into the cooling system itself.
Most controllers also have inputs for the electrical connection from the A/C clutch - when the compressor is running, the fans switch on also.
This is one of the nicer, more reasonably priced units I've seen:
http://www.spalusa.com/fans/automate...ts/FAN-PWM.pdf
