hard start
hard start
i have a 97 f150 4x4 4.6 in the morning when its cold out side truck is hard to start have to give it gas to keep it running for about 30 sec then is fine no codes or check engine light any ideas? makes remote start worthless in cold weather? hopefully someone has the answer?
Cold Start Problem
I am having the exact same symptoms. Started last winter, then was fine for the summer. Now its 15 degrees and she takes a good 30 seconds before I can take my foot off the gas without her dying. I searched IAC but didn't get any hits. What is IAC? Any help would be most appreciated. I have an appointment to bring it into a local mechanic next Saturday.
Positive that it isn't a gas problem. It's been a problem for over a year. It only happens on a cold start with a cold engine. After the first 30 seconds, it's fine and purrs like a kitten. Saw on another thread that cleaning the IAC helps, or replacing it. I'm going to the shop on Saturday, we'll see what he finds.
I would clean the IAC yourself rather than bring it to the shop. Half the time the mechanics will figure that you dont know the difference between the IAC and a tire, so they'll do a half-*** job of it. Mine did the same thing that yours is doing, I took the IAC off and blasted it out with carb/throttle body cleaner. Now it fires right up.
