Where is the shrader valve on a 2002 Supercrew?
Yes I did do a search for "replace gas/fuel filter" and found many interesting articles but I am still uncertain as to the steps I need to take to replace my fuel filter.
Questions:
1) Do I have to release the gas pressure, and if so where is the shrader valve located on my truck? (pics with an arrow pointing to it would be great)
2) Do I have to remove the gas cap before replacing the fuel filter?
Will I need anything else to remove the filter other than the fuel replacement tool?
3) Is there anything else I missed?
NOTE: I am planning on buying a motorcraft replacement fuel filter. (Alteast I got this right)
thanks fellas...............
Questions:
The schrader valve is on your fuel rail, a little valve, hard to describe, but in this case, not necessary to mess with. You only need a new filter and the white line seperator (plastic) tool that fits over the steel line and pops the seal. This is not easy for most so be patient. There is nothing else that needs to be done, just a little fuel will spill out so keep the filter as sraight as you can. Don't even touch the tank filler cap or nothing.
I am also about to replace my filter for the first time, so will be picking up a set of the white plastic disconnects. Exactly how do they work? I'm assuming that they slip over the line and you push against them to "pop" the seal of the filter/line??? Any guidance appreciated. I will be changing this weekend. Thanks.
Using the fuel line tool
Good luck.
I've always found the little plastic rings to be a pita. Shoot even the 10 buck X shaped deal don't always get it, but since I do enough of the filters the snap on set was worth it.
Call me a rebel for disaster, but I've never had to depressure the system. Quick tip is to slip the plastic shipping cap on the old filter from the new filter to keep it from draining all over.
Adrianspeeder
Adrianspeeder
Went to the local parts place today and bought a tool for removing the filter. They didn't have the white plastic ones, so I got the "x" shaped one. Got home to read in my manual as to which fuse to pull to disconnect the fuel pump. I must be missing it, but I can't find mention of it on any fuse diagram/list (2005 5.4). Any help out there? I did read about the fuel pump shutoff switch (where and how to reset). Thanks.
Buddies came over to do there plugs last fall 2004 & 2005 supercrew's. Watched a hockey game re-run and a few pop's to let the trucks cool down a bit. While they worked on the plugs I did the filters without a prob - a little gas spilage , but not bad. I used this tool -
The blue one works the best..
On another occasion, I just did a friends a couple months ago with a 2001- now that was a MF!!! I couldn't get that thing loose no matter what I tried lol. Once I finally got cheesed off enough just to rip it out of there , it still took 10 darn minutes in the vise to break that clamp free.. Mannn , that thing made me mad lol..
It was most likely due to the fact he used a Fram filter on the last change out..
Freakin Thing!!
Freakin Thing!!
