Releasing Fuel Pressure?
Hey guys, quick question.
Do I have to disconnect the fuel shutoff switch behind the kick panel and cycle the engine, like I did on my 99 Ranger, prior to changing my fuel filter?
'04 5.4 screw. Or does it get released when you pull up on the tab at that blue clip?
Thanks for helping, I don't feel like a gas bath today..........
Jeff
Jeff
on
Originally Posted by bogman
In engine compartment on driver's side upper side on firewall is a green plastic cap about 1/2 inch diam. Remove cap and press the pin in the Schrader valve to release fuel pressure, catch the little fuel discharge in a rag. Do a search, somebody posted pix a year or two ago.
WRONG! Ignore this...
That grea plastic cap is the service port for the evaporative emissions system. It should have an identifying tag on it.
You have this port confused with the Schraeder valve for the fuel rail...
Steve
projectSHO89:
I referred to the GREEN plastic cap on the driver's side firewall that covers the Schrader valve and there is a white tag on a hose connected to it. A GRAY cap is on the passenger side and down lower - is that what you are referring to? Please reply so I am not confused and I certainly don't want to post incorrect advice.
Thanks,
Da Bogman
Thanks,
Da Bogman
