Hey Quintin
Hey Quintin
I can't ditch these codes
P1132
P1152
Rich both banks (manufacturer controlled fuel and air metering codes)
I replaced both the upstream 02's, redid all the vac lines and even pissed on the wheel, to no avail. You pretty well know what I have. I don't think there are any vac leaks, and I have replaced all the lines. I do sometimes get P0401 (I think) which is the EGR flow insufficiant. I have been fighting these two codes for over a year, and you know I have emissions up here too. Whatdaya think?
P1132
P1152
yeah. I just found the electrical ghost in the machine this week. Had run something off fuse 19 (instrument cluster and air bag diagnostics) and when I removed it, the pin had expanded so the fuse wasn't making constant contact, and for whatever reason the damn alternator wouldn't charge. I rigged it, and put a little piece of wire in it. Works perfectly
