LOUD noise when starting up?
mine would grind, i took it out it was fine except for the washer on the very tip of the shaft was wore out, i mean broke and almost half of it was missing... i probably coulda fixed it myself if i knew thats what was wrong before i got a new starter...
hell i think it even had a c-clip on its tip holding that washer.
Originally Posted by yz450f
so you just suggest that i check the starter? and if the teeth are bad replace it?
how much do they go for? about 120?
