cold starting noises
My truck makes a similar noise when real cold, about zero to 15 or so.
As describe in this post http://www.ford-trucks.com/forums/5...ng-problem.html
But it only lasts for about 2 seconds at most I would say vs.30 seconds, just when you first turn it over.
If I plug the block heater in it does not do it.
Mine did it again today for about 3 seconds or so, it is 5 F out.
Also my dad has the same truck and his did not make any noises.
Both sat for the same amount of time.
Any one else experience this noise?
Anybody know what it might be/ how to fix it if there is a fix?
I know that some noise is normal when it is really cold out, but why would mine do it and mine dads not?
thanks for any help
06 F150 5.4 1,900 miles.
thanks for any help
Mine makes noise every morning when I start it up, temp is around -30C. Goes away once it warms up a little. Just that the oil is thick and doesnt circulate too well at first. You can switch to a lighter oil 5W instead of 10W during the winter. Power steering is also a little stiff at first too, the trans is a little sluggish when I first put in drive. But dont worry about it, its not hurting anything
Update
Well I went to the dealer yesterday to get some free oil change coupons and I asked my service adviser about the noise. And this is what he told me. That Ford knows about the noise on cold start up at 5f or below. He said that their have been a lot of trucks in lately with it being so cold with the noise. Said that Ford knows about the noise but does not know what the noise is being produced from or have a fix yet. Then I told him that my truck makes the noise and my dad’s truck does not, he looked at me like I was speaking in a different language . Said that’s weird and that my dads truck will probably start to make the noise too….I thought ya right. Then said that their “service guys” think that it is something to do with the PVC something or another. Could it?
I forgot to ask him if it could have been the fan cultch though. Do they make noise?
But it sounds like a load of BS to me with ford knowing about it and everything…and with his response when I told him about my dad’s truck not doing it.
The Stealership is moving at the end of the month and is already laying people off, so I wonder if that has anything to do with it???
starter rattling
I live in PhX,AZ and when it gets cold (relatively speaking in AZ that is less than 40) my starter rattles for about 2 seconds. This happens only about every 2 years.
I take off the starter an regrease the planetary reduction gears and the bendix shaft. The grease dries out due to the heat and when it gets cold it gets sticky.
I know this noise, it's like a "errrrrrrrrrrrerrrerrrrrrerrrrrrer" for a few seconds. The colder it is the longer it lasts. I've popped the hood before while it was doing it, but it was so loud I couldn't pinpoint anything in time before it went away. My gut tells me it is either the power steering pump or the fan clutch. I will probably never know unless something fails.
yep thats the noise, and you are right about how long its lasts to. When its a 0 it will last for 2-3 seconds, when it is about 10-15 only about .5-1 second. I don't think that it is the powering steering, I know that noise form my last truck.
But the more and more I ask people and the more and more say that it is the fan clutch.....which it could be I guess?
Noise
