Ford Racing 5.4 3V Ported Heads
Does anybody have experience with these heads? I called Ford Racing and asked about HP rating but they said they don't give out HP numbers...just flow increase.
20% increase in intake flow and 30% increase in exhaust flow are approximately what HP? Are they worth $1,399 plus installation? Will probably need cams as well...
http://www.fordracingparts.com/parts...tKeyField=9447
HI!... I just read your link and it says they are $1399(U.S) EACH!!! That's $2800(U.S) plus taxes. With S/H I bet they would cost you about $3000(U.S). They say nothing about larger valves, if the valves are S/S, what kind of valve job do they have? 3 angle or 5?
If you want heads then check out these links :
http://www.livernoismotorsports.com/...lar%3A+3-Valve
http://keyword.netscape.com/ns/boomf...eracing.com%2F
HI!... Well My old 5.4 with 9.0:1 compression made only 251RWH.P and 330RWTQ. I built up a 5.4 with the exact same mods as the other one, but added FOX LAKE stage II heads (now stage III) and custom COMP cams with a lower 8.42:1 compression and made 354RWH.P and 392RWTQ. Thats a increase of 103RWH.P and 61RWTQ!!!!! I'd go after market for heads. At least a stage II.
