Cleaning The Idle Air Bypass
My 4.6 has been making a wierd noise and its sounds like a humming. The humming went away when i gave it gas or was running at any rpm abouv idle. Hence why i went strieght to the idle air bypass. I found it was making the noise s oi pulled it off. It looked real dirty and all crudded up. Is there a way to clean it up or do i just have to bite the bullet and go buy one for $70. Somebody online was disscribing a filter in the back after you took of the sensor. How do you get it apart?
I use "Deep-Creep" made by Sea-foam, it cleans and lubes at the same time.
If it's real bad - use brake cleaner(or carb cleaner) and compressed air (shot of B-Fluid -then blow that crap out of there) first , then Deep-creep or WD40
Move the components by hand(small pair of needle-nose) to free them up good.
Look closely for any deposits on the rod itself (usually black) - try to get those without scoring the rod and she'll idle smooth - reboot the PCM after(You should have the neg. off anyway before performing this procedure)
If the "Rod" is too f'ed up (pitted) or other , you need to replace. I still have my stocker- has 206,000 on it lol..
Another note: I don't use gaskets on anything above the lower intake - gaskets leaked(even new ones, on mine), I checked w/propane. I now use "Permatex RTV High heat silicon" Black, cures faster and no leaks.
No, but take that off anyways to clean, also clean the elbow it bolts too. Throttle body cleaner works good, with a toothbrush. The IAC will work good probably till this time next year or two years but at least you'll know it works. After cleaning the truck may idle funny, wait for a bit it's normal. Mine would idle then raise a few rpms, say 150-200 then back down. I didn't disconnect the battery also so probably do that to avoid any issues. Keep in mind that cleaning just prolongs the enevidable, a new one costs around a hundred bucks or so (cheapest) I've heard about.
Oh ya, be careful taking the IAC bolts out and remember that there is a gasket, don't loose them, be careful.
I've clean the TB with TB cleaner. Had it working for a while before it started again. I then did a little more reserch and found out about the IAC. Went back in with some TB cleaner and was going to remove and clean the IAC. I must not know where the IAC is. I thought it was on the right hand side of the TB attached with two brass looking screws. I unpluged the wire from it and tried to turn the screws be couldn't get them to move. Started to strip the head of one so I stopped. You say that it has bolts. I know jbrew shows a pic of one off the TB already. Are there any more pics out there? Thanks for all your help! Trying to keep it away from the dealer $$$!: eek:
Only the 97 is on the side. I posted a pic of the 2000,(in the back) just 4 threads down from yours , here click on the link to see were yours is -
https://www.f150online.com/forums/sh...d.php?t=268079
LOL - WD40 don't last long enough to gum up - work great for loosing up the components , I blow it out with air , it does two things - frees everthing up and when you put the air to it it forces lube into areas you can't reach - been doin it for 206,000 miles ..Just common sense needs to be used , like dialing down the pressure.
