Troyer underdrive pulleys installation questions
Saturday I am planning on installing my underdrive pulley set I got from TP. I was hoping anyone else who has done this could give me some pointers.
Things I'm worried about are removal (told this is trivial with a pulley puller) and reinstallation (if the pulley isn't perfect wobble can be BAD).
Any suggestions would be much appreciated.
I've never had any problems installing dampner pulleys. But when removing them, with a puller I've seperated them. But that isn't really a problem since you will be installing a new dampner anyway.
Just make sure you use some High Temp RTV in the keyway behind the Dampner Washer like told to do in the instuctions.
Good Luck,
Doug
