04 5.4 Excessive ticking at startup for 2 seconds after sitting for 36 hours
Can anyone explain why this could be? On a cold start after sitting for approx. 36 hours the lifters, I think, sounds like they are dry as a bone. The command center says low oil pressure but within a couple of seconds goes away and sounds normal. I've heard about the anti-bleed back valve in the motocraft oil filter so that's what I use. A friend mentioned that it could be a lifter that some how got turned around. Ford has gone into the engine to replace the "cam phaser adjustment", not sure what that exactly how far they had to disassemble the engine. At 35700 miles this truck has had many problems, but I'm sticking with it. I've got to get it back to the shop for the eighth time before my warranty is up. I do have the extended warranty. Any help is greatly appreciated.
Xpress183
Xpress183
Originally Posted by streetracer9050
I have the same problem, the dealer said "it's normal" their favorite words. I contributed the noise to, after a period of time the oil drains down into the pan and on start up, it take a few seconds for the oil to return back up to the lifters.
Any info on whether this causes damage later on?
Originally Posted by xpress183
Thanks for the help.
Originally Posted by fishx65
My 03 5.4 started doing it at about 50,000 and my 99 Explorer started at about the same time. Never had any engine failures but did notice that they started eating a little more oil between changes. It might just be normal engine wear.
Xpress183
