Idiots at the Ford dealer
You know that really is irritating. You take your truck to the Ford Dealership because you wnat it to be worked on by someone who knows what they are doing. If all you wanted was an oil change by someone who knows nothing about your truck you could certainly get it done cheaper somewhere else. I'd make a complaint with your dealer. I Usually give them a chance to make it right and if they don't satisfy me, then I go elsewhere. Usually they'll do whatever they can (within reason) to in order to keep you happy.--DIY
on
Originally Posted by Gear Jammer
I got an oil change at the local Ford dealer today and for the second time now they put in 7 freakin' quarts. My truck is a 2001 model and takes 6 quarts, not seven. This is really starting to **** me off!!!!
Exactly, I only took mine in for it's first and that's it. For a few reasons, my purchasing dealer is 45 mins away so it aint worth it just for an oil change. But the local dealer scared me when a service kid walked in and asked "how much oil do I put in?" I dropped my jaw. Never let a potential customer hear that. I take it for granted, I read my service book, says 5.7L of 5w-30, so I dump 6 bottles of Castrol in, close enough. To verify, I check the dipstick and it's to the half point, maybe closer to full so I don't worry. Original guys claim involved an 01 which is the same. The dealer has the info or specs for capacity, if not do it the old fashioned way.
The 7 quarts they billed me for was not my concern. I pulled the dipstick once I got home and that's when I noticed that it was overfilled. I wouldn't be so aggravated about it if this were the first time it happened. It is definitely what I consider to be a good bit past the full mark on the dipstick. I am usually a pretty easy going guy but this is plain and simple carelessness.
Well said...
Fock that's bad!!! I would never go there again. How can you trust the dealership if they don't how oil to put in there? That's the simplest of the simplest of procedures and done more frequently than anything else.
on
Time to have a talk with management at your dealer.
Arizona Dealer Idiots
Berge ford in Mesa
Any dealer in AZ that starts with Earnhardt. the clowns hydrauliced my engine fixing a fuel leak and then hosed up the intake manifold gasket putting it back together. They gave me a BS story about the engine started knocking on a test drive. sometime later a parts clerk at the local Checker was helping me put in a new battery. recognized my car. he said he was working as a mechanic in the next bay when the so called mechanic started up my car and it immediately punched a rod through the pan.
tells us the name of the dealer so others can avoid the idiots
