Burning antifreeze!!!!!!!
Yes , if your intake manifold gasket is compromised around the water jacket, you usually smell it and later ,develop a miss. Also check your trans fluid level , check it right tho. It's possible that it's leaking within the cooling system.
Theres a line under the plenum that's been known to leak - check the cavity on top of the block behind the alternator for that.
Most Likely , It's leaking above #4 cylinder , your heater core lines. Hard to find that leak because it evaporates so fast. Look on top of #4 coil for evidence.
Good Luck
Good Luck
