changing plugs on 2000 5.4 efi
I don't understand why. I hear that people are removing it on both 4.6 and 5.4 engines. I did my plugs on my 4.6 without removing it. I did however unplug the injector's electrical connector but that's it. They weren't that had to do that I felt the fuel rail was in the way. I also have heard if you do disconnect the fuel rail from the injector you will need to replace the O-rings. From my experience I have to say no it can be done without removal.
Originally Posted by jbrew
4 8
3 7
2 6
1 5
Front
The 5.4L is a little wider on top - bout an inch.
3 7
2 6
1 5
Front
So I also had the plug #3 issue with my 4.6 in my 02 at 47K. I did not replace the cop, after I replaced the plugs I dove it another 9K before I traded it in with no more problems. I'm still not sure why you guys needed to move the fuel rail to do the plugs in yours. After I disconnected the fuel injector I had enough room but I may have used a swivel when I did it.
