1997 4.6 V8 F150 belt issues
Hello all,
I have been plagued by a really bad squeal in my F-150. It was owned by an old gentleman I knew and I purchased it from him. Its a 1997 with only 17,889 miles on it, he never drove it. Well, I've went through the darned thing, last summer no belt squeal, this winter i found and replaced the bearings in the idler pulley were bad, that was fixed and a new belt was installed. Now it is squealing really badly with a direct relationship to the RPM, below 1500 no noise, above its noisy. No idle noise. Could I have a set of bearings in the belt tensioner that are bad or have gone dry? COuld it be the damp weather, even though the belt is around 10 days old? Local folks say WD-40/ abrasive hand cleaners with grit in them to clean the belt off. Also a recomendation of baby powder to "soak up" the oil on it. I think it is the bearings because of the inconsistency of the noise, it isn't constant/regular.
Any ideas before I hand it over to a repair man? Please help!
Dustin
Dustin
Here's what I did to isolate my squeek and repair.
I sprinkled talcum powder (not constarch based) and sprinkled on the belt. Squeel went away so I knew it was belt slipage. Replaced with a gatorback and have been happy.
Here's a tip, go to schucks web page and order your new belt online, print your invoice and pickup at the store. You'll save a few bucks that way.
good luck
good luck
You mentioned that you changed a bearing in one of the pulleys. If the bearing was not a tight fit into the pulley it can spin inside the pulley and generate a squeeling noise. Just a thought. Also your tensioner may be weak allowing the belt to slip. Get some belt dressing and spray on the belt to see if the noise stops. If so the belt is slipping on the pulleys and it is either contamination on the belt or the tension is not suffient enough. Also are you sure you bought the correct belt for you engine? There are various sizes for the 5.4 and 4.6 depending on vehicle. Some of them are real close in size. Another thought is did you get the bolt tight on the pulley that you repaired when you reinstalled it. If not the pulley can spin on the front cover boss and make a noise. Good Luck
Originally Posted by jbrew
Good Info in this thread for yuh - Is that the original Serp belt? With that little of miles , the belt may be rotten from sitting..
he said he put on a new belt-read the post -WTF you are always busting someone else's *** for not knowing what they are doing
"that was fixed and a new belt was installed"
Hey all, well I have come down to the conclusion that the belt tensioner is the source of the problem (lack of sufficent tension pressure) and/or the pulley alignment may be out of sync. It is going to a good ford man I know that does fantastic service work. I would rather he find and repair the source of the belt noise/issue.
Dustin
Dustin
Good to hear you're on the road to getting that issue straightened up. To respond abuot the Gatorback, you'll probably get a few people that tell you they're no good, but I just put one on my truck a couple weeks ago and I'm thrilled with it. It's quiet and was no more than $5 more than on OE Replacement at AutoZone. Also in response to someone's suggestion on putting belt dressing on the serp. belt...not a real good idea from my experience. The best bet is to let your friend replace the tensioner and see what happens. If for some reason he has to replace the belt, I'd recommend a gatorback.
Welcome to the site. Sounds like a nice truck.--DIY
