different 4.6 engines, what is the difference?
Old 01-04-2007, 01:59 PM
cyman73's Avatar
Hello all,
I am in need of a new engine for my 1998 F150. The bad motor is the Windsor (VIN 6). I have many options with rebuilts, but I would like to know the difference between all other 4.6 liter Ford motors out there.
For instance can a 4.6 SOHC motor from a 2001 Crown Victoria fit in my F150?
Can this motor fit in my truck?
http://cgi.ebay.com/ebaymotors/01-05...QQcmdZViewItem
What needs to be exact for a match with my truck, year of the motor, vehicle origin, VIN code?
Thank you.
Old 01-04-2007, 02:16 PM
built54's Avatar
that should work... but if you want 100% perfect fitup, get one out of your year of truck, so all the wiring and everything is the same, even though it should be for any of them. the 99+ I believe, have the PI heads, i know its 99+ for the 5.4, not 100% sure about the 4.6.
Old 01-04-2007, 02:37 PM
cyman73's Avatar
This e-bay motor says no PI heads. Can you tell me what PI heads are?
Thanks.
Old 01-04-2007, 02:46 PM
jbrew's Avatar
Thanks.
It not a truck motor - diff. manifold as well..
Old 01-04-2007, 03:03 PM
tritonpwr's Avatar
2001 and up for PI 4.6's in F150's. Even so, there are lots of 01's that are still non-PI from Ford using up leftovers from the prior year.
So if its 2001 and up, it's about a 75% chance it's PI. 2002+ all 4.6's were PI.
Old 01-04-2007, 03:11 PM
cyman73's Avatar
So can I use a 2002-05 4.6 motor in my 1998 F150?
Are the PI heads compatible with the non-PI head intake and exhaust manifold?
Thanks.
Old 01-04-2007, 03:17 PM
s1037s's Avatar
the non pi intake willl not work on the pi motor, the exhaust may line up but the egr tube may need modifications
Old 01-04-2007, 03:20 PM
jbrew's Avatar
[QUOTE=cyman73]So can I use a 2002-05 4.6 motor in my 1998 F150?
1998 - 2003 5.4L or 4.6L
If you get a PI , it's to your benefit , but you will need a tune for it to rune correctly.
There 's a little more work in hooking a 5.4 up , but it's not bad..So you can consider both..
You have to make sure you get the whole motor - intake, everything..
Are the PI heads compatible with the non-PI head intake and exhaust manifold? no
Old 01-04-2007, 05:21 PM
Neal's Avatar
HI!... All you want to know about the 4.6.
http://www.babcox.com/editorial/ar/eb40228.htm
Heres the difference in the NON "P.I" to "P.I" heads :
Quick Reply: different 4.6 engines, what is the difference?
