Code P0125 (Closed Loop Fuel...) Advice?
My "service engine soon" light is on. The OBD Code is P0125 which is "Closed Loop Fuel Control Insufficient Coolant temp"
I cleared the light once and it came back in a couple days. Anybody know where I should start looking? Stuck open Thermostat? some temp sensor??
2001 Ford F150 Supercrew 4x4 4.6L , 83K miles.
Thanks.
Thanks.
with CHT Sensor
with CHT Sensor - DL110 DTC P0125: CHECK ENGINE COOLANT LEVEL
Diagnostic Trouble Code (DTC) P0125 indicates the CHT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting engine. This DTC will light the MIL.
Possible causes:
Insufficient warm up time.
Leaky or stuck open thermostat.
Low engine coolant level.
Malfunctioning CHT sensor.
WARNING: TO AVOID PERSONAL INJURY, DO NOT UNSCREW THE COOLANT PRESSURE RELIEF CAP WHILE THE ENGINE IS OPERATING OR HOT. THE COOLING SYSTEM IS UNDER PRESSURE; STREAM AND HOT LIQUID CAN COME OUT FORCEFULLY WHEN THE CAP IS LOOSENDED SLIGHTLY.
Check engine coolant level.
Is the engine coolant level fill correct?
Possible causes:
with ECT Sensor
DA80 P0116: CHECK TEMPERATURE SENSOR RESISTANCE WITH ENGINE OFF
Note: Verify that engine temperature is at ambient room temperature before continuing with this test. A soak period of 6 hours may be required. Refer to Diagnostic Trouble Code (DTC) Descriptions , in Section 4 for information concerning P0116.
Key on, engine off.
Disconnect ECT sensor.
Measure ECT sensor resistance. Refer to the chart at the beginning of this Pinpoint Test for resistance specifications.
Is resistance within specification?
Yes No
GO to DA81 . REPLACE suspect sensor.
Key on, engine off.
Yes No
on
Originally Posted by satexasf150
ECT engine coolant temperature sensor and CHT - Cylinder Head Temperature (CHT) Sensor
The 2001 4.6 uses the CHT sensor. There is no ECT sensor on this vehicle.
Does your in-dash TEMP guage read lower than normal, does is show a delay in reaching normal range, etc....
Steve
Steve
Steve
Easiest Thermostat I've ever changed. I had to remove the power steering reservoir bracket and then take the 2 thermostat bolts out. No need to remove the water hose from teh housing. Of course I drained the coolant first. The easy part was the o-ring gasket. No scrapping old gaskets and using RTV.
