ran codes on my "03 supercrew
C.O.P. - (coil on/over plug)
PLUG - Sparkplug - inDhead~CopDcover.
Thought we covered that.
We just told you how to fix , cause , you asked.
You have a "Coil On Plug" system in the 03 . It's common for a plug or coil to go bad every now and again..That's what were getting at . Misfiring for long periods of time is bad for the cats. PO301's Injector is probably good, but dumping raw fuel down #1. You need to fix it.
You have the code #1 's first one pass. side (towards the front of the truck.).. After time goes by , your PCM may shut down your injectors in an effort to protect your CAT's - so, yeah , try a plug and a COP from Auto-Zone.
COP's
PLUGS
Heres a pic of #1 - The one you need to fix -
A pic of injector #1 - down by the oil filler cap - that orange thing sprouting from the fuel rail and blowing un-burned fuel thru #1 . The COP and Plug are behind that out of view.
COP's
PLUGS
well it started it again..coarse it rained last night..install new plug old one looked good still missing pulled cop off with truck running it was firing..put it back on them I pulled the injector harness off #1 there was no change same miss didn't get any worse.. you guys still think c o p ?
He said there was no change unplugging the injector. ???? Significant change when unplugging COP. AND , it's missing at idle..I realize COPs miss under certain load values, this ones misfiring at idle , it has no fuel to ignite or very little..Therefor primary and secondary are good. His injector F'ed..
